In response to a request by hardworkingstiff from another thread, I am going to share with you my experiences over about 30 years where I had an arc-flash event.  Thankfully, through dumb luck more than anything else, I survived all four events without injury.
Event one: Adding a subpanel to the garage in my parent's house. I was installing the 40amp DP Zinsco (cringe) breaker in the main panel, which in finest Zinsco tradition had no main breaker. I was having a lot of trouble getting the 40a DP to seat, so I had the brilliant idea of placing my screwdriver on one of the terminals and hitting it with the palm of my hand. Yep, you guessed it...I smacked the handle of the screwdriver, the tip slipped off, broke the side of the breaker and sent my best screwdriver across BOTH live bussbars!
The explosion woke up my dad on the other side of the house, he ran out in panic expecting to find me dead. Instead he found me holding the stub of my favorite screwdriver cussing up a storm. Other than ringing ears for a few hours, no injury. I was not wearing any PPE of any kind.
Event two: Same house. Was installing insulation in the attic and discovered a buried flying splice. Traced visually the romex, went to the dreaded Zinsco panel and shut off the affected circuit. Back in the attic, picked up the romex and cutters, realized my gloves were too cumbersome and took them off. Picked up cable and cutters again, was about to cut the wire then for some reason put both down and put my gloves back on. Picked up cable and cutters, went to cut and BOOM! The cable was still live. Ruined a good pair of cutters and again ticked me off. Figured out that I had traced the romex to the wrong place and I had shut off the wrong breaker.
Event Three: Working at a drive-in theatre on one of the projection consoles which had a built-in breaker panel, fed by a 50a DP breaker. Troubleshooting a problem with the lamp power supply. It is controlled via a contactor. The contactor wouldn't pull in, so I had the great idea to push it in manually, using an insulated tool. What I didn't know is that the power supply had a dead short on one leg, and when I pushed that contactor in the shorted leg/pole shot out a huge arc which flashed over to the other leg creating a nice fireball about a foot from my face. Niether the breaker in the subpanel or the booth panel tripped. Oops.
Event four: I have told this one on the forum before, but it bears a replay. I was doing a service change working for a local EC. I was trying to pull the meter but it was stuck. Following the advice of one of the POCO guys, I slapped the meter once on each side then started to pull it out, tilting down from the top. I heard a loud crack, then there was a huge boom as the meter shot past my face and landed in the middle of the yard. Turns out the top meter clip was bad, and I broke it loose and the hot clips hit the top of the meter can. I climbed up and cut the drop (Which I should have done first) , then proceeded to remove the old meter can with a 20lb sledge. The meter met the same fate next. :grin: When the POCO crew arrived for the reconnect, luckily the crew foreman was a friend, he took in the scene and laughed. I offered to pay for the damaged meter but he said no problem, they were getting a new one anyways. My PPE that day was a short-sleeve cotton T-shirt, sunglasses and leather gloves.
I look back on those and realize how lucky I was to have escaped any injuries (other than ringing ears and damaged pride), as any one of those could have ended a lot worse.
I now take proper precautions and unless troubleshooting, work it dead.
So let's hear your stories of close calls...
