you will need to look at the box that the wire nuts came into see what the manufacture instructions say.
The issue is not with the NEC but with the manufacture of the wire nut. I know that on the ideal green wire nuts you Can only use 4#12S
5 for a red of many modern types is not uncommon. Even then - as it depends on the model - there are listed combinations that are not even on the box/bag, but available from the manufacturer as it is quite a lot of info to but on a small box... Like on page 2 of this - the dot represents a listed combination on the graph.
So if it were that model number - he might be eatin' crow.
And if it were one of these - note the graph is set up different - it the vertical column, PLUS the horizontal column - he might have to eat a pigeon...
If one of these - only in certain combos of #12 solid with stranded would he have a leg up in giving someone a red tag for something so silly as a unsubstantiated rumor or myth, or grasping for an nonexistent code.
Oh - I had that guy on my crew some time back - 'Mr. Screwgun is in charger - so sit on butt'... He has a brother called 'I left all of my tools at my side job' - I sacked them both.Good link.
I could have used this 20 years ago. Had a left-handed helper twisting the wirenuts the wrong way (counter-clockwise).
"3. Turn connector onto wires in clockwise direction until secure."
Why would you sack them for no tools? That's the average guy now. You're supposed to keep him in tools and provide transportation and lunch too. Didn't you know that?Oh - I had that guy on my crew some time back - 'Mr. Screwgun is in charger - so sit on butt'... He has a brother called 'I left all of my tools at my side job' - I sacked them both.
Back to the links with instructions - note the parts about twisting or not twisting wire first...
You sack 'em for low/no production. Hand tools are your stuff... A screw-gun is a personal luxury - sans that I don't care how big your forearms get.Why would you sack them for no tools? That's the average guy now. You're supposed to keep him in tools and provide transportation and lunch too. Didn't you know that?
One was AKA 'Side Show Bob' - because he looked just like him...With names like that I wouldn't have hired them in the first place. :grin:
as shown in post 4, the Ideal red wingnut is not listed for 5 #12
It's listed from 1 to 5, so.........that's 5.........right?
