100323-1037 EST
electrics:
First, I assume you do what the code requires.
Then the question is --- what problem do you want to solve?
If you need to keep radio frequency interference out, then you need a screen room as a minimum.
Are you worried about interconnecting different pieces of equipment that reference a signal to the chassis and that chassis in turn is required to be connected to the EGC? Solution here is to use an isolated type of interface if possible. In general Ethernet is isolated by transformers in the data path. Straingage elements should be isolated from ground. The measuring elements in LVDTs are usually isolated from ground. Sometimes thermocouples are grounded at the measurement point. This might mean the need for an isolation amplifier. Current loop stuff is usually isolated at one end of the path.
Computer stuff, if no isolation is used, needs to have all the associated equipment plugged into the same outlet strip. We make optical isolation devices for use in RS232 communication over long distances between computers and CNC machines. This isolation of the conductive path between the two ends of the communication path solves the ground noise problem that in some cases is not solvable by direct connection.
Do these comments stimulate any specific questions?
