So, this "load bank tap box" is a J-box, with the incoming conductors connected to the outgoing conductors? Maybe it has bus work for the connections, or Ilsco Power Distribution Blocks? No switches? Was it supplied as part of the load bank equipment?You run cable from input of the box back to generator paralleing gear, from box output, you run cable to the load bank or we called it "load bank tap box"
Does anyone knows if there are any restrictions on generatror load bank tap box?
