Load bank tap box
anbm
TX
Designer
Does anyone knows if there are any restrictions on generatror load bank tap box?
You run cable from input of the box back to generator paralleing gear, from box output, you run cable to the load bank or we called it "load bank tap box"
So, this "load bank tap box" is a J-box, with the incoming conductors connected to the outgoing conductors? Maybe it has bus work for the connections, or Ilsco Power Distribution Blocks? No switches? Was it supplied as part of the load bank equipment?
I'm trying to get a handle on what is in this thing.
cf
Typically all the load bank tap boxes I have seen are home made with a bus arrangement, PDB, Camloc's or are NFSS's.
