dmagyar
- Rocklin, Ca.
I've got a prospective client wanting to reduce his electric bill and I noticed he has a 5 hp 240 volt single phase irrigation pump setup. What would you consider to be a good way to check the sizing of this pump to the work it was doing? I've checked nameplate FLC amperage noted at 23 amps, and while running this motor is drawing only 18.5 amps. I'm thinking its not too loaded for a reading like this. I've got the motor torque curve for the existing motor and a 3 hp that may be sufficient for this application but wasn't sure of my logic. Any suggestions appreciated.
