Paul.Downie
Hi, Any help would be grateful.
I have a question regarding dynamic braking.
Motor Details. Series DC Motor The supply to the motor when the dynamic brake resistor is connected to the armature in parallel is 216vdc battery fed.
I understand that the Back emf is dissipated into the resistor to protect the VFD and the motor. What I would like to grasp is how the resistor slows the motor down. The supply 216vdc is held onto the motor until a limit switch has been activated and stated the motor has reached home position.
The dc motor resistance is 4.8ohms and the dynamic resistor is 18 ohms 500 watt.
Voltage is proportional to speed so I assume that the volatge drops can anyone explain this in more detail withs some calculations to back up theory.
Thanks Paul.
Thanks Paul.
