Hello guys,
I am new here and wanted to see of you guys can help me clarify a question on NM-B wiring.
I am estimating a 5 story apartment building and I wanted to know if NM-B was allowed for general circuits INSIDE the unit. I got the idea from a remodel we did in a penthouse of a 51 story building. I went out to see the job and saw that all the 15 and 20 branch circuits were done in NM-B.
Now 334.10 says that in type III building it is allowed. This is a tunnel form job, so all the walls and ceilings will be concrete and the exterior walls will be CMB. Concrete has, I believe, a 2 hour fire rating.
So, is there a code section that I am overlooking. It has been a while since I work the field and use the code mainly for motor calculations and 310-16 and 310-15(b)(6).
Thanks for the help.
