You must bond the pipe because it is likely to be come energized.
"At least the Oil Burner Emergency cutoff switch is properly marked"
How do you know it supplies an oil burner? or is this in your place![]()
I think that the words "Oil Burner" and at the bottom of the picture, you can barely make out what appears to be the last 3 letters of the word "Emergency" might have been a dead give-away.
The holes are so you have a way to feed the solder through.So THAT'S what the holes in the plug blades are for!
Don't laugh. We found almost the exact same thing (minus the EMT) under a house a few years ago, where someone unknown relocated a range during a kitchen remodel.
But for solid wire only. You can't get stable tension using stranded.So THAT'S what the holes in the plug blades are for!
