I am installing lighting poles on a bridge. The bridge came with 5/8" piece of steel over the edge of the bridge with a 4" radius hole cut in it to sit the pole on. I have RMC ran under the bridge then i am changing over to seal tight. The problem i am having is with the 4" radius hole in the supporing steel plate for the pole i dont have anything to keep the seal tight in the base of the pole. Anyone ever come across this. If so what did you do?
