Double Taps on Breakers
  • Yes your house will burn down.
    Votes: 1 2.2%
  • No your kids will burn your house down first.
    Votes: 15 32.6%
  • Yes they should be addressed (removed, repaired).
    Votes: 28 60.9%
  • What is a double tap?
    Votes: 2 4.3%
  • Total voters
    46
Because many of us see it daily in thousands of installations without them showing any problems. It was not always a code violation.
This does not mean I do not follow the code myself or suggest that others do not. It just means I do not make a huge deal over every violation I come across. It would be a waste of time.
The question was not if it was a Code violation. The question was if it is a problem.
I expressed my surprise how many did not see this as a problem. You pick an argument with that. OK, we agree to disagree.
I agree that ".... I do not make a huge deal over every violation I come across. It would be a waste of time.", however when it involves conductive or insulating parts it never is a trivial issue, does not matter how many does one sees operating fine.
I find this akin to driving while drinking. Does every time a driver drinks causes an accident?
This topic comes up a lot.
Most of us know what breakers allow two wires.
My question is: Is it a 'hazard' to have two wires under a breaker that is not rated for two?
Does this cause an overload?
Does this cause the breaker not to trip?
Does this cause arcing?
Bottom line is it a safety hazard?
I call this out but will the house burn down if it is not changed?
I had put an extension on my old house. A string of outlets from the new room were tied into an exisiting load center. There was no more room for new breakers. So I was told by the inspector to wire nut the old 15amp circuit to the new and run a short third wire to the exisiting breaker. He would not allow both #14's in the same breaker even though they fit tight. Just as they won't allow a string of room outlets to be wired into each other using the built in jumper scews. I had to pig tail everything with wire nuts in each box. So why make the duplex with 4 screws? It Just made for a more cramed box. And they worry about fill space in conduit?:confused:
He obviously wasn't enforcing the NEC.
