JWCELECTRIC
- Massachusetts
I am in the process of designing an electrical upgrade at a pump station with 2 levels. The station is real tight to install new electrical equipment & panels. Can I mount a 208, 3P, 4w distribution panel above a grated opening to the lower level? To get to the lower level the grating needs to be removed. In the past I have not put any panels above openings with grating. Is there anything in the code that says the panel can not be above the grated opening? Thanks
- JWC
- JWC
