GBBOLT
- Trenton, Florida
I have just finished wiring up 10 condos and while hot checking I have found that when I first test a device with my arc fault tester the device will trip like it is suppose to, but after I go and reset the arc fault breaker and try to trip the same device, my tester shows a flashing light and will not trip the same circuit that I tripped the first time. What is weird is that if I let that circuit sit for a minute or two after reseting the breaker and then put my tester on it it will usually trip that way. Bottom line is that I can not continuously trip the circuit, reset, trip the circuit, reset, and so on. It seems like you have to give the breaker a little time to reset itself after you trip it the first time before it will let you test it (trip it) again. Is this common. Every condo is the same way, once I trip it the first time it gives me trouble each time there after! HELP!!!!!!!!!!
