A/A Fuel GTX
- WI & AZ
- Electrician
Would a residential entry way, coming into a dwelling from the outside, be considered a hallway or would it fall under 210.52 (A) (1) (2) ?
The entryway is just that and nothing more. What is on the inner side of it is not bore upon by the entryway. The only issue it bears upon, afaicr, is receptacle spacing.Would a residential entry way, coming into a dwelling from the outside, be considered a hallway or would it fall under 210.52 (A) (1) (2) ?
As for myself, I use the definition "foyer:a vestibule or entrance hall in a house or apartment" and consider such as a hallway.
(I) Foyers. Foyers that have an area that is greater than
60 ft2 shall have a receptacle(s) located in each wall space
as defined in 210.52 (A)(2)(1)
I agree with Smart$. The entrance is simply an opening. The receptacle spacing would be dependant on what area the entrance opens into.
If the entrance opens directly into a loving room, kitchen , etc as defined by 210.52(A) then the receptacles would be spaced accordingly.
If the entrance opened into a hallway the 210.52(H) would apply.
