Greengiant1964
- Central Valley California
I was looking in the code seeing if its permitted to have a grounding connection directly to a fire riser on a commercial building.
The fire riser under the ground is plastic and then runs up to metal on the vertical.
The existing ground looks to be #4 or larger ground. It appears that the ground is for IT room.
Just needed some clarification, I was performing a fire inspection and noticed this.
Thanks
Thanks
