It was previously two singles and the guy who installed the new double had just combined the existing wires and upped the breaker to a 40
Conclusion: its a bad job.
Even if paralleling was permissible, which it isn't because of the wire size, there's the other matter of identical lengths, construction, thermal state etc, and I suspect that a couple of independently run #12s are unlikley to be of identical length, so they shouldn't be paralleled on that basis either.
Thats the kicker. Anyone with sufficient nouse can figure out that this is probably OK, and anyone with a clamp meter can check that it is actually paralleleing and loadsharing reasonably well, and thus it is (in practice) an adequately safe arrangement.The use of two conductors in paralel is a clear violation of the NEC but is most unlikely to be dangerous in practice.
