wbalsam1
- Upper Jay, NY
Do short sections of raceways such as EMT stubbed thru floors require adapters and bushings to protect the NM Cable or is it permissible to simply ream the EMT? :-?
You need a bushing to change from EMT to NM. The code used to read, "fitting". It didn't say what kind. But now you actually have to have the right fitting
I think this makes good sense. Will you please provide the code section? Thank you in advance.
Working off memory,,,,334.15,,,,b,,, i think calls for EMT
314.42 calls for bushing
I think there's another in there somewhere
300.15 (C) Protection. A box or conduit body shall not be required where cables enter or exit from conduit or tubing that is used to provide cable support or protection against physical damage. A fitting shall be provided on the end(s) of the conduit or tubing to protect the cable from abrasion.
raco makes a changeover from emt to a rx connector
