I came up to a job installing a hot tub. The existing sub panel only has three wires making this a 120v sub panel. Can I convert this to a 4 wire by just adding a ground rod and connecting existing wires to the proper connection of two hots and a neutral in the main panel plus the ground wire to grounding bar in sub panel being fed only by the 7' ground rod?
