LarryFine
 - Henrico County, VA
 - Electrical Contractor
I was told by a GE field engineer about 25-30 years ago that each line's pair of breaker bodies is made up of one current-sensing unit and one auxiliary-contact body.But why the breakers in parallel? I don't see the advantage, but applying Occam's Razor I see a disadvantage.
How are they rated? Do the ASSume that the current will split perfectly as engineered between the breakers? What if one of the four fails?
He said this was done for the purpose of reduced overall contact resistance, which I took to mean less FOP across the breaker set. I guess the bodies are cheaper, too.
In more recent times, however, someone (maybe here) said that my explanation is wrong, and the 4-pole unit is really made up of four similar 100a breaker bodies.
So, unless someone wants to drill out the rivets on such a unit and let us know what they find, we may never know the truth. Maybe we can't handle the truth.
