as someone said, you can cascade them. Also, just from a design point, it might be good to install inline fuses at each pole, so if there is something bad at that pole it wont take out the whole circuit. Also, if you plan to use more than 1 circuit, its good to 'alternate' them, in case a circuit does trip.When doing voltage drop calculations do you figure the longest distance concerning 1pole or do you need to total all poles then figure your greatest distance. I have 9 poles in a parking lot and I am not sure on the calculation
Thanks
Another aspect is if the poles form a grid so to speak: e.g. 9 poles in a 3 ? 3 arrangement. The first one would still be 9 loads, but it can then branch out two or three ways.The home run has 9 loads, the next section has 8, the next 7, etc. Cascading conductor sizes is common, as the last run has only a single load.
Just a note on that method... it is only good if using the same size conductor throughout the run.There is a 'formula' for coming up with what is called 'the load center', or the mathematical middle of the various loads.
This is from a 1940s-era handbook.
Substitute your numbers (and add more if necessary) to calculate the 'center' of your lights. Use that figure for voltage drop.
