shamsdebout
 - Macon,GA
Based on the values from the utility engineer the bolted 3-phase fault for a 500 KVA. 208Y/120V pad-mounted transformer is equal to the phase to neutral fault (phase to neutral fault less than bolted phase to phase).  I am not an expert but with the little I know, this doesn't seem correct.  We normally make the assuption that the bolted 3-phase fault will cause the maximum short-circuit current.  When the engineer was asked if this is common or seems right, he said this is how it worked out this time.
Has anyone ever gotten similar information from the utility or have verified by calculation that this can happen?
