manofsteel2616
New member
I have a question concerning variable frequency drives. When hooking two or more motors to one drive, would you use external overloads for each motor or is there another way to protect the motor? I wouldn't think one would want to use the parameters because they would have to be set high to cover all of the motors connected. For example, motor a's ol's are set to two amps while motor b's ol's are set at eight amps. I would assume the parameters would be set at 10 amps but if motor a was the only one running, the ol's wouldn't trip until 10 amps when it was rated for 2 amps. Are my assumptions correct or am I in left field? Thanks
