gar
- Ann Arbor, Michigan
- EE
100420-0639 EST
dbuckley:
Several comparators for zero crossing detection are: Analog Devices AD8561, AD8598, AD790, and AD8611. You many need slight filtering on the output.
NE555s or LM555 can be used for phase shift adjustment.
For SPDT switches Analog Devices ADG419 and Maxim and Vishay DG419. These have 30 t0 40 ohms on resistance and need to be followed by an appropriate high input impedance amplifier.
Some useful simple amplifiers are AMP-01 (50 k input), AMP03 (25 k input) for input to the switch.
For an output amplifier consider an ordinary OP7 using the positive high impedance input or an instrumentation amplifier such as AD620, AD625, and AMP02.
On the switch connect S1 input to common or ground, and S2 to your signal to be gated. D is the output to a high impedance amplifier.
These components allow a system with a response from DC to the upper limit of the amplifiers.
Although I created the tube type gate and I have reports showing the waveforms I do not remember the details of the gate and quickly I can not find any details of the circuit.
dbuckley:
