zbang
- Roughly 5346 miles from Earls Court
What is "retorque", anyway?
I think that most folks mean "put the torque wrench on the bolt and see if it clicks" (assuming a clicker torque wrench). I've always used the word to mean "back off the bolt and bring it up to proper torque again". The former meaning is, frankly, nonsensical. You can't get torque without motion, and if the bolt/nut is already properly set, you over tighten it (the usual complaint against the practice). You also have to overcome sticktion just to get it moving.
So, does anybody back-off/re-set bolts or just check to see if bolts have actually been tightened?
