Is it acceptable for feeder cables to a motor to be warm to the touch? The insulation is THHN, rated for 90 degrees C. The engineer had ordered a thermal scan, and the temperature on the cable surface was about 55 degrees C. The cables are really heating up the conduit, which doesn't seem right. Will the cable insulation be fine as long as the temperature is below the rating, even though it feels warm?
