transfer switch question
wireguru
Would a manual transfer switch between two portable generators need to switch the neutral? Each generator has a N-G bond.
I'm having trouble picturing this because I don't know if the generators are tied to a common earth ground, or if there is bonding somewhere down stream.
Ok i saw the setup today. It is two diesel generators (120/208Y) mounted on one trailer. Common ground. They want to use a manual transfer switch to be able to move the load from one generator to the other. Can this be done with 3 poles or will the neutral have to be switched?
