ishium 80439
Anyone who has worked residential or retail has done it.  Broken something, drilled through something unintended, marked up a rug etc.  My typical reaction is to do the best I can to minimize the apparent damage and than tell the owner.  My question is if you do a good enough job of putting it back together are you "covering up" or did you fix the problem?
In the past I remember drilling through a built in cabinet. It was in the back corner and wasn't visible unless you really looked for it. I happened to have some wood putty (it was actually almost like an epoxy) on the truck and was able to cover the hole and sand it down to a level finish. I never told the HO about it. Was that wrong or did I fix the problem?
This comes up because today I was pulling out a previously installed old work recessed light and the paint stuck to the rim. When I pulled it out I ripped off some paint w/ it. I was all ready to give the HO the number of my painter to redo the ceiling but when I put the can back in I was able to match up the chip and the texture of the ceiling was such that I was able to spread some mud on it and it pretty much went away. I'll admit it wasn't perfect and that if you look right at it you can see the rip, but I truly feel that it will be invisible to virtually everyone who goes into that house.
So did I do wrong by not bringing the HO's attention to it or did I fix the problem? (And any other tales of breaking stuff would be fun to hear)
