Cow
- Eastern Oregon
- Electrician
I have a project requiring an EMI/RFI filter to be installed on a 60HP wellpump running off a drive.  Is it kosher to use reactors in conjunction with filters?
I previously installed a filter on 125HP wellpump for the same customer, but the reactor was unhooked already(I assume because it went bad?) so that particular pump only had a filter on the line side of the drive. No reactors whatsoever.
This 60HP has reactors on the line and load side of the drive. Does it matter where in the circuit I stick the filter? I was planning to put it after the reactor and before the drive....?
The customer has a machine that reads ear tags on their dairy cows when they're loaded on a carousel. Supposedly when this well and other VFD controlled motors run it causes a lot of misreads with their equipment.
The existing reactors:
http://www.transcoil.com/Products/InputSide/KLR.htm
The filter I'm using:
http://www.transcoil.com/Products/InputSide/KRF.htm
