Looking for a good sealant for soldered wires
Cow
Eastern Oregon
I have a bunch of soldering to do and am looking for a good sealant I can goop around the connections before I put the heatshrink over it. I'm using the good Thomas and Betts adhesive lined heatshrink. What I'm doing is running a 12-3 SJ cord and making splices every 4' to add a pigtail that's runs a pulsator for a milking machine. The heatshrink will basically be wrapping around two cables leaving a void between them I need to fill with something. Scotchkote is a little too thin, I'm looking for something almost like caulk, that'll easily fill a void without needing to be applied/built up over several coats? I'm definitely trying to avoid silicone, I'm trying to get 10+ years out of this install. Maybe some sort of epoxy or resin that's safe for rubber cord/wires? I went through the 3m and T&B catalog and couldn't find anything.
Does anyone have any ideas?
What's the cable used for? Are these splices in a box?
Have you thought about something like this? The 3 cords would come out the three small ends and you would shrink the big end around a PVC cap after you have made the splices.
Try this link they have the aqua bond - guns - nozzles
http://www.aquabond.com/
It powers the pulsators which milks the cows. And no, these aren't in a box, they are low voltage. They are under the carousels milking platform where they are constantly being dripped on and hosed off.
Larry I'll have to look into that stuff. I've never used it.
Wireguru, I'll try that too. But I'd sure feel better if I could squirt something in there first.
Don, I had a look at those breakout boots. None of them would shrink down to a 3/16 OD wire, plus my supply house guy told me they were $41 apiece. With 72-80 milking stalls on each carousel and the fact I have to do 4 carousels, it'd really add up.
Winzip, I'll take a look at your link.
Gunning, I don't think tape would work that well. It would still wrap around the cables just like the heatshrink would and leave a void.
I appreciate all the responses, thanks guys!
i thought of another (and better) option (i dont know your budget or how quickly you need it) There is a place near me that makes molded rubber Y adapters and such. As I recall, they have a mold for a 'T' adapter, they could make you the cord with however many molded rubber Ts with the pigtail coming out. I think each molded splice is going to run $15 or so. PM me if you want more info
This is the product you are looking for cow. I have used this stuff for the break out wiring configuration you described countless times. Flexible, waterproof. Works great on many other applications too. They also make a UV rated version.
This 6100 is the high viscosity "no slump" version. I get the caulk-tube size and cap the end of the tube with a bolt and a couple wraps of tape when I'm done. Lasts a long time.
http://eclecticproducts.com/_tds/e6100_tds.pdf
This stuff looks perfect. Does it handle the heat alright when the heatshrink is being applied?
Silicone
Silicone
Would you reconsider filling the void with silicone. If you leave a little bit of slack at each splice you can completely cutout and replace the entire splice in the unlikely event that the soldered splice will give you trouble. Are you going to support the splice from strain with tieraps? If so, can you make a loop of slack cable there?
This is what we use for splicing uf cable.
http://www.diverssupplyinc.net/browse.cfm/4,871.html
Good luck,
Jim
