Fluorescent lamp with 6500 Kelvin
siva
hi
Specification requires 32 watts fluorescent almps (U type or straight) with 6500 degree Kelvin color temp.Is this type available from any manufacture?Anybody can help..???
Thanks / Siva
Re: Fluorescent lamp with 6500 Kelvin
Hi..
Sorry ,I forgot to mention the fixture type.It is a 2' X 2' type.
Thanks / Sivaji
Sylvania makes 6500K straight 48" lamps, but I don't see it under the U shaped lamps.
A 5000K seems to be the highest color temp. for a 32W T8 U lamp. An FBO32/750/ECO for example.
Steve
Edited because I thought one was a U shaped lamp, but it is actually straight.
[ April 07, 2005, 09:23 AM: Message edited by: steve66 ]
GE makes one. "Starcoat" F32T8/SP65 is the 48" lamp. (32W) Also see some T-5's at 6500K. The highest U-type is 5000K from GE. GE also makes an 18" T-8 w/ 6500K (15W). It's F15T8/D. Why do you want/need that high of a color temp? What's the application?
The lamps you are looking for are in the "daylight" range of 6000k to 7000k (towards the blue end of the spectrum) This should be a commonly stocked lamp at your supplier.
[ April 08, 2005, 09:04 PM: Message edited by: bigjohn67 ]
Siva,
Usually if the engineer specifies a 6500k lamp, they also have a CRI rating specified too. Just double check that whatever you select covers all the specs.
The sylvania catalog has some of them listed for store display and sign lighting.
Steve
