We all know that grounding networks made up of rods,conductors and grids in a closed loop through out a facility proper with taps to different pieces of equipment is an effective way to ground equipment and it always has a path to ground if the main ground loop conductor is broken or severed in any way.The integrity of the system remains in tact.
This brings up a question involving the grounds of a service panel and subpanel.Lets assume we have a driven rod at the service panel/meter loop that is all tied to the main panel groundbus which in itself is bonded to the main panel neutral bus.We now extend the two hots(120/240), a neutral and a ground to a subpanel.The neutral bus at the sub panel is isolated from the ground bus at the sub panel. Lets only talk about connections to the ground bus from device ground terminals via the branch ckt ground wires at the sub panel.This ground bus as stated previously remains isolated from the neutral bus.Now going back to the opening paragraph and the effectiveness of a ground loop that provides more than one path to ground,,,,,,,,,can this same basic logic be applied here?In other words if a second ground wire were added to the subpanel ground bus, exited the subpanel by its lonesome and routed(direct buried) remote from ground wire in the sub panel feeder conduit all the way back to the ground rod at the main panel and used as a loop ground wire and used to ground additional equipment along the way, thus giving all device's two paths to ground.If this can be done, can additional rods be added to the remote ground wire to maintain low impedance on the ground system as the sub panel is 700 feet removed.
Done safely and all within Code parameters of course.
I think I covered it all,holler if something is amiss.
dick
dick
