WastefulMiser
- ANSI World
I've never been in the process of commissiong (start up) of control / power room that is located in a classified area (Class 1 Div 1/2) where they used NFPA 496 to purge the air inside the facility in order to declassify the interior to unclassified.
I was wondering what is the best way to provide power to the purge equipment? I believe ideally it should be from a separate source (not within the enclosure) routed in a NEMA 7 disconnect, etc. How would you account for redudancy of power if you wanted to tie the purge into a power source that would be located inside the area you are purging. I'm assuming a NEMA 7 ATS would work, but would there be other options? What is the standard practice?
I've also heard of people during commissioning to get around having to provide a separate source using an apparatus to "sniff" the area inside the room to detect the presence of gas, thus being able to use a source inside the area they are declassifing to operate the purge equipment. Is this a common practice?
I'd appreciate any education given on the subject. There may be several threads already on this subject, if so, could someone point me in the direction if they know of one?
