I need to add a conduit to a existing disconnect and not interrupt loads while doing so. Does anyone know the sequence required to open the door on this disconnect while in the "on" position? I have looked at the cams on the unhinged side of the device and it does not seem to be as easy as the Square D disconnect that uses the spring loaded screw head to release the door lock. Thank you in advance, BTW here is a photo of the old boy
		 Hope this is landing in the correct thread...
Peetmin
			Peetmin
