Will Wire
- California: NEC 2020
- Electrical Contractor
I recently worked on a 208v three phase air compressor motor in which the electrician before me had grounded the motor with a one foot piece of metal flex conduit from the grounded motor control box.  The flex has ends listed for grounding, but enters the motor junction box through reducing washers.  Is it required by code to use a grounding bushing or grounding locknut where the flex enters through the reducing washers?  If it is necessary could a bonding wedge also be used?  Thank you.
