Ravenvalor
- Triad region of NC
- Electrician
I have a customer who has a humming noise coming from her wall or floor behind her bed. The noise stops when I turn off the receptacle circuit which runs in the wall behind the bed and feeds the receptacles in that room. It is a 3-wire cable with one conductor being switched from the wall switch. The switched conductor feeds half of each receptacle in the room. I unplugged all of the appliances plugged into those receptacles but to no avail. She did not want me to dig into the problem because I had already been there for a while on other projects. Does anyone have a suggestion or two? I have never heard humming noise coming from a cable except for ceiling fan switch legs.
Thank you,
Jim
			Thank you,
Jim
