DaveBowden
- St Petersburg FL
A customer wanted 3 low voltage lights on his back deck to come on when he turned on the carriage lights outside his back door. We installed a gfi receptacle with an in-use cover for the lovo transformer to plug into and tied it on the existing switch. When the switch is turned on, the gfi trips. After the gfi is reset, it doesn't trip again until after the switch is turned off and then back on. We had a similar problem a couple of years ago with a gfi receptacle feeding a fountain. Held forever as long as the circuit stayed energized but tripped when the switch was first turned on.
Any ideas what could be causing this?
