bejoyengineer
Hello ,
I am confused a bit with these questions
1. I have read that ??Transformer nameplates carry a vector group reference such at Yy0, Yd1, Dyn11 etc. This relatively simple nomenclature provides important information about the way in which three phase windings are connected and any phase displacement that occurs. Digit 0 means that the LV phasor is in phase with the HV phasor,Digit 1 that it lags by 30 degrees,Digit 11 that it leads by 30 degrees? I also read that? When viewing the voltage and current waveforms on an oscilliscope, the two curves would be on top of each other, in unison hence the name unity power factor.But when dealing with ac circuits you must also include a term called reactance (ac resistance) which can be composed of inductive loads and capactive loads. When viewing the voltage and current waveforms on an oscilliscope when reactance is involved, the two curves will be viewed as separate graphs. Either the voltage curve will lead the current curve (inductive type of loads), or the current curve leads the voltage curve(capactive loads).
1. So my question would be that when are the cases that the transformer is designed for different phase angles or in other words ? why and in which cases the transformer is designed for 30 degree lead and lags.
2. As explained above ??Digit 1 means that the LV phasor lags by 30 degrees
phase with the HV phasor and also as explained above ?the current curve will lag the voltage curve for inductive type of loads.? So does ?LAG? in both the cases have the same sense. Or in another words- the lag for the inductive load shows that the Power Factor is bad and so does it have the same meaning when it comes to the transformers i.e, lags by 30 degrees
phase with HV?
+++++++++++++++++Relay++++++++++++++++++++++++++++++++++++
phase with HV?
