fereydouni@sbcglobal.net
Sorry folks, I do not remember the complete question format or all of the multiple choice answers. Hope for the best and possibly some expert answers.
1. GFCI distance from inside the pool wall?
A) 6 Ft
B) 8 Ft
C) 10 Ft
D) 12 Ft
2. What is the maximum voltage for batteries put in series in residential?
A) 30V
B) 60V
C)
D)
3. How many 20A/120V outlets for continues light load 15KW?
4) As per title 24, at what number of outside lights photo sensors should be used to operate them?
A) 0
5) After a residential solar system was installed, customer complaint that the messages are recorded with a disturbance noise, is the problem because of?
A) Inverter
B) Telephone Line
6) 30A load berried in PVC in concrete should be at
A) 12 Inches
B) 36 Inc
C) 48 Inc
D) 6 Inc
7) Conduit run from inside the house to the outside, what is the best way to protect inside wires from moisture?
A) Special potty paste
8) Subcontractor electrician noticed on the walk through that the main panel is designed under size and was approved by the inspector. Whom should he contact?
A) Inspector
B) Contractor
C) Building owner
9) Under ground outlet found to be missing ground wire, the electrician must?
A) Install ground rod
B) Rewire ground wire to the main panel
C) Ground to the neutral
D)
10) Flood equipment should be on site before the work could start?
A) 25%
B) 75%
c) 100%
11) Roof flashing on a solar job is used to?
A) Stop rain
B) Stop dust
12) What type of conduit (Dust proof) should be used in a grain ware house?
A) 6 Ft
B) 8 Ft
C) 10 Ft
D) 12 Ft
A) 30V
B) 60V
C)
D)
A) 0
A) Inverter
B) Telephone Line
A) 12 Inches
B) 36 Inc
C) 48 Inc
D) 6 Inc
A) Inspector
B) Contractor
C) Building owner
D)
A) 25%
B) 75%
c) 100%
A) Stop rain
B) Stop dust
