Customer house was built in the 50's.  Old sub-panel has a feeder cable that doesn't have a neutral.  Just 2 hots and a bare ground wire.  All the neutrals and EGC's land on the same bar.  I want to separate the EGC's from the neutrals.  So I was going to pull a EGC from the main panel to the sub-panel.  Add a ground bar to the enclosure, land the EGC from the main I pulled in.  Then land all the EGC's in the sub-panel to it.  And use the bare feeder cable ground as a neutral.  Is this OK?  Thank you for your help.
