360Youth
 - Newport, NC
Got a call Friday morning from a job foreman to say that we failed CO on a new home.  Inspector said that most of the receptacles upstairs and about half downstairs had an open ground.  In my mind I am thinking that is a lot but ok.  I would go check it out. My first thought is a bad tester, but it was only some of the receptacles that failed.  After running several scenarios through my head on the way over there I get there and plug my tester in and all is good.  Check a few more.  Good.  Put meter leads on device terminals.  Good.  Had foreman plug in a saw and check against terminals with a load.  Good.  I figure inspector has a plug tester with intermittent working lamps.  He comes back this morning with a new tester, passes, apologizes, and moves on.  :roll:  I can't say this is the first time  have dealt with an inspector and a bad tester, but I would hope there would be some sort of back up plan, or a red flag might make him think to try a different tester.  I was not there for re-inspect this morning.  he was in and out before GC could get me down there.
