Bentley Building Electrical Systems V8i for AutoCAD
I'm the other guy, I've been a Intergraph and MicroStation user all my CAD career. I was a board trained draftsman in a third life.
This software listed above might cost as much as the AutoCAD Seat, I frankly don't know!
This software works in conjunction with a fully licensed seat of AutoCAD.
Here
or
Here there complete listing of seconardy electrical packages from the same supplier.
I believe this software (first link) has been out since version 8 or 10 / or 10 and 11 of ACAD.
It's not clear to me that you have existing plans; you need to make up some of your equipment arrangements or exactly where you are in these aspects.
If you have plans you can do several things, one is to scan the plans. I don't have a reference to any of that software but it is my understanding that this has come a long way, but one will pay a price. This also can go from 3K to 10K.(complete package) I do know that usually a scanner comes with its software, and only works for that scanner, the problem is that the file just turns into a *.IMG file (an image file). And depending on the software will t
une it up to an electronic drawing or not and usually through a drafters/CAD operator input.
The following is some of the draw backs of using an active data bases. (as I know it - and this is old history) These are still some considerations if you need record keeping on you files.
ACAD will display excel work sheets but at not be interactive to the screen.
Bentley doesn't do it at all for an excel file. But I think Bentley re-wrote their software to be about the same a ACAD (display - but not interactive to the screen)
I don't know what Data Base - ACAD ever used. (used or liked)
I do know Bentley loves Oracle. In your case this might be another expense.
Only pricy software (CAD) will give you the needed DATA Base interface.
I 'm not sure but I don't think the low end packages will even display, excel and data base have pop up records or the like, thus your problem.
