680.25 (b) 1-2 & 680.26 (b) 1-7
I was called to R&R a 240v/7.5A pool pump. The pool system is 15+ yrs. old and home owner installed. I believe that I found several violations. But I not clear in how to define 680.
1) To me, 680 reads that motor needs to be bonded with a solid #8, along with the rest of the electrical pool equipment or would a #12 be to code?
2) There's no grounding electrode for the remote sub-panel.
3) The sub-panel is mounted on a fence (no roof or cover) less than 3' off the concrete deck.
4) The Sub-panel is a Zinsco.
Any input would be helpful.
Mark
augie47
Tennessee
Bonding would need to be by a #8 minimum
Not necessarily a rquirement unless this is considered to be a seperate structure
How far is the panel from the edge of the pool ?
Bad news but not a Code violation
Mark
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
almost ditto. How long ago was the ground rod needed at a separate structure. The zinsco panel may have been installed before the code on this.
Let me clarify. A #12 is sufficient as the EGC for the pump. The #8 is only for the equipotential bonding-- i.e. tying all the metal parts related to the pool, together. The #8 does not need to go to the panel.
Cavie
SW Florida
Dennis, you stole my thunder!
Not necessarily a requirement unless this is considered to be a separate structure
NO structure. Just a fence. But separate from service panel.
>20'
EGC, Please define for me?
Forgive me if I did separate quotes wrong
Dennis Alwon
Chapel Hill, NC
EGC = equipment grounding conductor. That would be the ground wire you pull into the conduit to ground the pump. Is that what you wanted to know?
May I summarize my understanding:
The #12 Ground I installed from the new pump motor to the panel is to code?
The Zinsco N.G. but code.
There should be a #8 grounding electrode conductor to pool equipment (ladders, diving boards etc.) but not needed if the motor(s) are grounded with #12.
A new #8 conductor should be connected to a grounding electrode.
Cavie
SW Florida
yes #12 is code and a must.
yes Zinsco is code
#8 BOND (not electrode conductor) bonding all metal within 5' of the pool. No ground rod used.
#8 must always be used.
