To confuse the issue even more Cat6e is even outdated at this point.
There is now Cat 6A (augmented) as well as Cat 7.
FWIW we don't see RG6 quad used very often. In a normal house RG6 is fine. On a high end house they won't be using co-ax anyway.
If I'm not mistaken, digital signals depend less on shield coverage than analog signals do.RG6 Quad is the standard CATV coax being used now. It has better sheilding than RG6 to better support digital signals.
If you don't use coax what do you run to each location where you think a TV or a cable modem might be used?
Tell that to Comcast, thats all they run. I had a problem a few years back with a new install. Comcast came out and said it was because it was not quad shield. Well I changed out the cable to quad and the problem was gone.
For the slight extra cost, I'll install the quad it is a whole lot cheaper than the 5 hrs I spent replacing the other stuff.![]()
On a high end home they will be running component cables or HDMI cables to the TV's. This usually falls outside of our scope because they will engauge the services of an installer who will also do their whole house audio, ipod docking stations, intercom, theater room, as well as sell them the tv's and equipment ect.
I understand component or HDMI cables would be run to the TV from a A/V system, but what is run to each room from where the cable provider enters the home? I always run coax. Somebody above indicated there is something better that is run in high end homes.
