PhaseShift
Were setting up a panel yesterday that had 24V DC controls inside the panel and well as a few microprocessors.  Running through the panel we have 120V cables coming from the field passing through the cabinet in route to another location.
When setting up the panel we noticed that the processor inside the panel was giving a ground fault alarm. After tracing out each circuit, we determined that the ground fault alam was a nusience alarm and it must have been caused by something else. We thought maybe that 120V cables run through panel (3ft) may be causing this. So we changed the 120V cables in the panel to shielded cables and the problem went away. The 120V cables were serving switches in the field, so they had very little current.
Anybody ever seen this before? What do you think could have been causing this problem? Inductive or capacitive coupling between the 120V AC and 24V DC controls or something else?
