aidan011408
Will disconnecting the circuit under load (without turning off the breaker) damage computers or electronic equiptment? And if so please explain why?
If you disconnect circuit and creats sparks, than breaker will turn off as soon as spark creats.
I think something was lost in translation here Ekhlas, is that what you really meant to say?
The main thing which cause to the electronic equipment is voltage variation. That is why TVSS mostly used to maintian the voltage level stable.
How does a TVSS stabilize voltage? MInimize damage from impulses yes but under voltage or over voltage (depending on the clamping voltage)?
it has alot of things please see below
AC line..
You did not explain this statement.
No it is not a MWBC. If you remove the wire from the breaker before turning it off.
This is what I said. When a "TVSS mostly used to maintian the voltage level stable", I may have missed the word " in transient condition " but ofcourse everybody knows when we use TVSS.
I have already mentioned in the last post this " TVSS limits the overvoltage to a safe level". When something remains to its real condition, can we not call it stable?
suppose the voltage is 110 to 120 volts. when transients occurs, peak voltage level reaches several hundered volts. Eventhough, these pulese can be for a short time or microseconds but in that time they can cause hardware to malfuction. Specially when lightning strikes
A surge suppressor prevents the peak AC from going above a certain level. Can you not call it that TVSS maintains voltage level stable.
According to IEEE std.62.64
surge arrester: A protective device for limiting surge voltages on equipment by diverting surge current and returning the device to its origin. Is not explain stability?
NO, NOT STABILITY OF VOLTAGE, stability has to do with maintaing voltage between predetermined levels. Yes you can minimize over voltage, but under voltage is an issue also.
If you try to tell a customer you are going to stabilize voltage with a TVSS, I bet you competitors will be on you in short order.
I think you are confused between steady state and transient. I am not talking about the steady state voltage stability due to load ( over voltage, undervoltage, swell and sag ).
.sta?ble /ˈsteɪbəl/ Show Spelled[stey-buhl] Show IPA
?adjective, -bler, -blest.
1. not likely to fall or give way, as a structure, support, foundation, etc.; firm; steady.
2. able or likely to continue or last; firmly established; enduring or permanent: a stable government.
3. resistant to sudden change or deterioration: A stable economy is the aim of every government.
4. steadfast; not wavering or changeable, as in character or purpose; dependable.
5. not subject to emotional instability or illness; sane; mentally sound.
6. Physics . having the ability to react to a disturbing force by maintaining or reestablishing position, form, etc.
7. Chemistry . not readily decomposing, as a compound; resisting molecular or chemical change.
8. (of a patient's condition) exhibiting no significant change.
100515-2246 EST
Ham:
In the English language stable would mean without variation or at least with very little variation.
