old electron
I know that if a fence charger is plugged in to an outdoor rec., it must be a GFCI rec. But does the NEC allow the charger to be wired direct without CFCI protection?
			Please, Please, Please don't wire it in direct.
I know someone who grabbed onto a fence wire while they were barefoot and in mud.
They have the scars to prove it.
If someone had not unplugged the fence box, they would have been killed.
regards,
James
I'm not sure a GFCI receptacle would have helped. Actually, I'm pretty sure it wouldn't have. (I'm assuming a fence charger means its for an "electric fence" - the kind intended to keep animals inside an area.)
An electric fence charger is going to be isolated from the 120V supply. Thus, if someone grabs the fence, the current will flow from the fence, through the person, and back to the charger through the ground.
However, on the input to the charger, the current will still be flowing through a normal supply circuit - from hot to neutral. There is no "ground fault" to be detected by the GFCI receptacle.
If the GFCI receptacle tripped every time contact was made with the fence, the fence probably wouldn't keep the animals in.
Steve
I'm quite sure what he's referring to is the ability to unplug it,,,,,,not the GFI
A single belt from a fence is an item of merriment for the onlookers.Besides I do not think a properly working electric fence can kill anyone.
Get stuck under a fence getting shocked every second, and you do eventually die. Its happened many times.
Need a laugh: Braniacs investigate electric fences, UK TV programme excerpt. Don't be eating or drinking whilst watching this clip!
Correct; the fencer will not trip the GFCI, unless the fencer is busted or the cabling to the fencer has gone awry.In Theory, I don't think contact with the DC voltage of the fence charger would trip the GFCI.
And don't ever think you have to touch the fence. A friend of mine was out bird hunting in a dewy medow one day and came up on one. He simply pointed at it to tell his son not to touch it and bang. He said the last thing he remembered before opening his eyes and seeing his son laughing his butt off, was seeing the arc jumping from the fence to his finger.
James
Well what are the chances someone is near the plug at the right time?
How about a disconnect somewhere easy to spot?
