tonype
- New Jersey
With repsect to minimum service levels, is a condo complex considered a series of 1-family dwellings (100-amps minimum each) or a multi-family dwelling (60-amps per apartment).
While by definition it may be a cluster of single family, they are considered multi family in the building code. In the building code they would be an R-2 which is the same as an apartment (the only real difference between the two is that you rent one and own the other). An R-2 is residential occupancies containing sleeping units or more than two dwelling units where the occupants are primarily permanent in nature.
One reason the code must recognize that condo's are a single family home is the easement requirements for utility conductors, in a multi-family (apartments) building, utility can cross the boundaries of each unit, but in a condo each unit is a privet property and we can not trespass with the utility's to another unit, this is why fire walls are required, and many times separate metering to each unit.
If it were my call I would say separate one family houses, just zero lot lines:grin:
That's not necessarily true. Here the utility only cares up to the service point. After that we can chase the subfeeds to each unit. Now under ground might be the smarter way to do it, but nothing disallows you from running accross the units. Many have common attics. You only have gas meters at one end usually and you will run that piping through each unit.
On condo or town houses you own the thing and that now causes problems as unit #2 can not run wires thru unit #1 . It is all about ownership. This is so if unit #2 burns out his underground feeder he can not cut up the floor in unit #1.
That's not true. At least in my area, by law when you own a condo you don't own the space between the walls and floors between units.
In this discussion, as in many others, it is important that we are all using the same terms to mean the same thing. In my area, town homes are not the same thing as condos. Town homes would be like hurk27's example in post #7, where the owner owns his unit and the land it sits on. There wouldn't be any common spaces inside through which to run the utilities.
Condo's on the other hand would be as Peter D and cowboyjwc describe. The homeowners association owns the structure. The individual owner owns his air space inside. Attic spaces and underground would be owned by the association and governed by the homeowners covenants.
