peter d
- New England
I'm going to start splicing more often just to spite Zog.
I guess I will offer my thoughts (opinion:roll
I will admit there has been a few times where I under judged a run and had to "add on" to reach a box or the panel, I believe this happens to most all of us who try to keep wire waste to a minimum, but to do this on purpose I would feel that I was not doing a customer good service just because as was mentioned, it will be a weak point, 99.9 percent of all connection failures are at splices or terminations, very rarely are they in the middle of a run, now would I want an electrical contractor doing this in my own home? surely not, would I get upset if a contractor ran short and had to make a splice, probably not,
but to do it as a normal method, I would say its not ethical because the home owner is paying for the best job we should be doing, and the more splices, the possible more places moisture can get in a cause corrosion and failure even if we do a great job of splicing, soldering every splice? not very cost productive.
Pretty much how I feel. I think it looks "hackish" to add unnecessary junction boxes. But since I'm no hack, I reserve the right to decide what is necessary. :grin:My thoughts exactly!
would I want an electrical contractor doing this in my own home? surely not, would I get upset if a contractor ran short and had to make a splice, probably not.
See folks there is an easy solution to the problems of splicing. If you have a good excuse then it's OK. So on the box cover you leave a little note. Note**** To who it may concern, do not judge me harshly, I normally wouldn't splice but I ran short and that makes it OK . I'm not a hack, really I'm not. :grin:
I'm sure glad I don't do resi work, I don't have to worry about this one.
(I don't believe I would do it, but.... I have learned...... never say never).
