F frank.clowes New member May 18, 2010 #1 What are the requirements for 4160 volt creepage clearances between devices and enclosure walls?
roger Moderator Staff member Location Fl Occupation Retired Electrician May 18, 2010 #2 See all of part III of article 110. Roger
kingpb Senior Member Location SE USA as far as you can go Occupation Engineer, Registered May 18, 2010 #3 frank.clowes said: What are the requirements for 4160 volt creepage clearances between devices and enclosure walls? Click to expand... The term "creepage" when talking about MV equipment needs clarification. If you are talking about working clearances, then the Roger's post already answered it. if not, then could you be more concise on what you are looking for.
