Bill Peters
New member
What would cause classroom ceiling projectors to have a while faint line go up and down the screen? We have several locations with this problem different parts of the county. Each projecter is on a dedicated circuit. Each panelboard has been checked for grounding issues etc. We have turned off all circuit breakers in the panel except for the projector feed. No help. The projector mounts to a metal square pan. The square pan is mounted to the metal ceiling grid. A metal box is secured to the metal pan with MC cable. The only thing that works is to remove the outlet from the metal box and disconnect the ground. The white line will go away. We also tried isolated grounding recpts. Any ideas?
